Machine Simulation goes to XYZ 0 on every C axis Indexing.
Hey! I need advice from someone who´s played around with post processors and machine simulation.
How can i adjust the way the machine behaves on indexing / between ops? The autodesk posk for Brother M machines seems to do some return to XYZ zero on C indexing, and XY zero after every operation (when A is tilted).
Im trying to go though the code and figure it out, but having a really hard time.
Right now on every C axis indexing move, the machine simulation goes to XYZ "home" which is middle of the table, and than goes in an XYZ simultenous move down to the part.
When i dont have C axis indexing move, but have two operations with the same tool, that have the same tool orientation, the machine does NOT move to Z zero, but goes to XY zero, virtually crashing into the table.
Check video showing the exact issue.
Thank you!
