Hi @p_krola
This is an known issue and the team is aware of it. The reason behind here is the post engine expects the rotary head rider (B axis) should come first and then the rotary head carrier (C axis) for head - head machines while post processing but in the machine file hierarchy C axis comes first and B axis comes second this causes the post to fail to output the codes. the problem occurs only with the head-head configs only..
The workaround at the moment is to use the hardcoded machine config in the post processor or reordering the hierarchy as mentioned above will post the output codes.
Boopathi Sivakumar
Senior Technology Consultant
