Machine simulation does not currently check for machine collisions.
Qone0001
Qone0001
Hi! After update my fusion 360 CAM simulation is showing only from viewpoin of a tool, unable to switch to model viewpoint and shows me this message:
"Machine simulation does not currently check for machine collisions".
I can't figure out why is that.
There still is an option to switch to model viewpoint but when i shwitch to it, it stays at tool viewpoint.
Tom.Hemans
Hi @Qone0001,
Can you include some images/gifs/videos to show what is going on, and also attach the Fusion file so I can se if I can replicate it?
Tom
Tom Hemans
Technical Consultant
tero.palmioMVL8B
I have the same problem. In simulate even if I change view to model it still stays in a tool view
Qone0001
Also its not about file, as in my previous works everything was fine, and now any file i try, i get the same error.
mathew.hutton
Hi @Qone0001
Do you have a machine selected in your setup? With the November release, the machine simulation feature flag was turned on be default in this release, and so is causing the issue you are explaining about the tool remaining stationary. see thread: https://forums.autodesk.com/t5/fusion-360-manufacture/simulation-shows-stock-moving-not-end-mill-des...
It sounds like you just want normal CAM toolpath simulation for your setup and not full machine simulation?
You can remedy the issue by using a few workflows:
1) Delete/remove the machine from the setup selection.
2) Turn off the Machine Simulation feature flag in your preview features tab.
3) Edit your CPS file and remove CAPABILITY_MACHINE_SIMULATION.
Hope this helps
Mat
Mathew Hutton
Manufacturing Specialist
tero.palmioMVL8B
Problem solved. thank you for help 👍
deanjhkim
Observer
Observer
