Machine simulation Alignment and other machine builder questions
Hello, two hopefully easy questions about machine simulation and alignment.
First question is how do i set the machine and fixture up so that i dont need to re-align it when doing setups? i thought if i lighned up the machine origin to where i want the fixture to sit, and fixture (tombstone) origin in the same place, when i go into machine simulation, the two origins would overlap and id be set, but my fixture is way far away from where i want it to sit in the machine ( out of the machine entirely) Im trying to make it so i dont need to align things everytime, there must be a way.
Second question is where are the machines stored? its not in my assets, when i go to select the machine for machine siomulation, i cant select the thing that i was building, only an older version from when i started, and then a message pops up and tells me that theres a newwer version of the machine and it will use the newer version. but i dont know where any of this info is located so i cant just remove the older version and use just the newer version.
