Machine Simulation - After change of post-processor on the machine, unable to update machine definition
Le_Bear
Le_Bear
Not sure exactly how to describe this but a picture might help
After selecting the machine in Setup, I went back to the machine definition to change the post-processor, but since then, it seems impossible to update. Not sure if it's a bug or if I miss something ?
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
a.laasW8M6T
Hi I am also experiencing this problem, not just with updating the post but any change to the "Machine" cannot be updated, you click the update button and nothing happens, sounds like a bug to me.
I have also one instance of where I have removed a machine from the setup but the machine model is still there in the manufacture environment and I cant get rid of it. Turning the visibility on and off doesn't help either, neither does turning of the option in preview.machine stuck.png
Andrew Laas
Senior Machinist, Scott Automation
ELAFING
It took me a while, remove the machine from the setup first then remove it from the machine list. Make sure you remove it from the "document" section of the machine list.
boopathi.sivakumar
Hi @Le_Bear
Thanks for testing this out! yes it is an know issue and the team is aware of it.
as a workaround i have attached the short video here
Boopathi Sivakumar
Senior Technology Consultant
Le_Bear
Thank you for the work around. I think I did that once, without really knowing what I was doing..... 😉
Did not realize it was in the Document, though.
Bernard Grosperrin
