I'm trying to setup my trunnion table, and can't quite figure out what the A Rotary and B Rotary "Offset" values actually do. They don't seem to have any effect on my posted code.
I wanted to tell Fusion that the a-axis axis of rotation is 3.59488 inches below (in Z) my Work Coordinate System (WCS) which is at the center of the b-axis plate. I thought I could enter this number into the offset in the machine configuration for the A axis. However, this seems to have no effect, and when machining with a tool orientation other than zero, the post just assumes the part rotated about the WCS, not an a-axis a few inches below the WCS.
I suspect I'm just not understanding what this offset value is supposed to do. However, I really do need some way to specify that the a-axis and b-axis are not about the work coordinate system, because mechanically these two axes are not perfectly aligned (the a-axis is a couple thou away from where the b-axis line crosses it). And I'd like to set my WCS at the center of the B axis, not at some unreachable point in the middle of the trunnion where the a-axis rotates about.
I'm using the stock machine setups and posts from the Autodesk library from "HAAS with AB-axes" (Pre-NGC) with the "hass trunnion.cps" post. This is a pre-ngc machine, which has no tool center point control. I have TCP turned off in the machine setup.
Thanks for any help,
-Peter
