Machine library error
broncomech
broncomech
I am attempting to add my machine to the local library and keep getting an error.
I copied the autodesk generic 3-axis setup to the local folder, modified to match my machine and every time I try to save it throws this error.
This document does not appear to be associated with a hub and can not be activated
pramod.pk2XX6G
Hi @broncomech
I'm not sure about what cause this error message, but I believe there is a way to preserve your file. Try to export the machine file to the local computer folder as Fusion Archive (f3d) and then try to reupload the machine file to the proper hub where the machine should be added to the local machine library of the cam setup.
Pramod
broncomech
Thank you for your assistance, after several failed attempts I now have the machine saved in my local library without the error message the previous 5 copies generated. As I am not sure which one Fusion is using I will leave them all in the local folder and move on.
