New to cam. I'm practicing on this part. Decided to do a 3d adaptive roughing with .5mm stock left and boring out the hole. Then I wanted to do another 3d adaptive with .2mm stock left and a finer stepdown. For the 2nd operation I wanted to leave the hole alone and do a 2d contour much later on it. So I chose to uncheck 'machine cavities'. Problem is in the geometry tab if you set it to 'none' it still machines the cavity. A duplicate operation simply selecting silhouette resolves this issue and the cavity is successfully avoided. Any thoughts on why? In my attachment I suppressed the operation that has 'silhouette' used. The one active shows the cavity being milled. Thanks.
