looking for help with hurco VMX42srti post
Hi all, I'm looking for some insight /help on the Hurco post from the fusion library attached to this post.
So I trying to get the post sort for are vmx42srti machine so from all the post I read on hurco post alteration seem hurco controller doesn't need or read the H offset (example 705) and I read doesn't read the D also but I have noticed on the uptodate post the a tick boxes to possible turn them off picture show below.
Also, there is the use of the G43.
So I am wondering for any fusion 360 user of this machine or that use the hurco post turn these off as seem hurco doesnt like tool created on fusion tool library with the standard T705 h705 and d705 like other machines it ok with the T705 but the other 2 I read and I seen the H705 error that excesses value when u try run the program.
But not tired of a G41/42 tool path on the machine yet to confirm if we get this error if we have our control or wear option on tool paths, and will these read theHurcoo controller tool data ?
Also, for adding iso program to the Hurco program, it asks for M99 but then posts the end of the program with an M, as seen below.
X1.063 Y14.977 Z-1.017
X1.121 Y14.95 Z-1.114
X1.157 Y14.933 Z-1.177
X1.215 Y14.902 Z-1.287
X1.268 Y14.868 Z-1.401
X1.274 Y14.863 Z-1.416
G0 Z18.427
M9
G69
G0 M140
M31
M35
M13
G0 B0. C0.
M127
G53 G0 X0. Y0.
M61
M2
E
Is the m2 correct, like the m30 at the end of a mazak iso program, if the program was a complete iso only program, or is the m99 used for subprograms and full iso only programs?
Is anyone one can help with these questions, or has a post that cancels out the H?? Offsetet and the D??? If that's also a thing, as theHurcoo controller ignores this, as it just read its tool data under the tooT705
Look forward to helping with this, as I can then get a lot more part made on are Hurco machine for 3-axis and 5-axis machines.
Many thanks ahead of time, tho can help solve this or tell when I need to change in the post to achieve my issue, or a post that has already been changed, as I guesg there's going to be other issues I come across,s but these seem to be the main ones to answer.
