looking for 5 axis advice in reduce the wasted movement
hello all
I have come to group again in search of a better answer to my problem I have attached the following is the post use for the 5 axis mill I run NC code it generated and the file with model and tool paths it self
with all the select on the post I selected and run with
so as u see from the program and NC code it created make program run for 58mins but good part that time it the c axis rotation goes from C0. then turn passed 360 degrees up to pass 3000 deg rotations in the C axis
each time it pick up the flow tool path it just added from the last C position the C axis figure but it start back at C0. but then roation to let say 760 in the c axis then starts from there so that 2 full turn in C axis when tool just spinning in the air.
so why not starting from C0. in stead do that movement back to last c axis figure (hate waste machine time ideal spin in air) so doesn't have to move the machine so much and waste time one it completed one of the flow tool paths
so I am looking to see is there way to make all tool path there own (N1)(M01 so can run op stop) so if stop the program can jump to that tool path with out have run all path from that tool
as I haven't found way to make all tool path let say using a 6mm which is doing bore and adp roughing and finish which on the setup would be 3 tool path but when i post all seem to be under 1 set of tool data (H1)
so if I missed a simple way of making it do this with M01 after each tool path other then added a manual NC code
other then trying to post each tool path and pasting them in a way to reduce the c axis wasted movement to try seep up program and able to jump into a individual tool path be great step forward to me and my company
any help to reduce the wasted movement would be great
look forward to help and replies
many thanks
