Are you using a PC for Fusion? If you are, on the post dialog there's an option to open the post processor, Open Config. This will open the post in your editor, just search for 53 to find the lines outputting G53. I guess you have a couple of options, you could comment out the line or change the G00 to a G1 with a feed your steppers can handle. Do other rapids in Z cause problems?
Mark
Edit. If you edit the post don't save back to the generic folder.
Test the post carefully and I'd better add this
The accompanying advice and or non-standard post processor is provided as-is and without warranty of any kind, and usage is at the user’s own risk.
Do not put custom posts in the generic posts folder. Use the personal folder. or another location.
Fusion 360 CAM Personal Posts Folder Locations
_______________________________________________________________________________
Microsoft Windows:
%appdata%\Autodesk\Fusion 360 CAM\Posts
Mac / Apple / OSX:
/Users/<user id>/Autodesk/Fusion 360 CAM/Posts
Mark Hughes
Owner, Hughes Tooling
