Lift tool between stepovers
danpayneuk
danpayneuk
Hey guys
May seem like a simple question but I cant seem to find a way to allow the tool to raise between step overs on a horizontal tool path or pocket clearing.  The final finish shows marks where the tool repositions.
Have read about offsetting contour in sketch and doing a 2d contour for each step over, but that seems are rather bodge way of doing it.
engineguy
@danpayneuk
Have you tried using the "Use Morphed Spiral Machining" option? This does not usually use the "transition" moves so may be a better option for your finish 🙂 🙂 🙂
Stay Safe
Regards
Rob
danpayneuk
Hi Rob
No I haven't.  I will have a play with that and see if it works.  Thanks for the tip.
Michael-Kmosek
Observer
Observer
Yes, that does remove the transitions but it also makes the finish look like a form of adaptive clearing. It would be nice if it would lift and ramp down into the next layer.
John_Wright
Have you tried "lift height" on the linking tab? I don't know if this will help with your particular issue, but will raise the tool up above the surface when linking cutting paths.
