left over bits in narrow areas
I creating a 3/16" deep pocket in some cursive writing that has narrow spots. I'm also running a radius along the bottom of the whole pocket.
Adaptive clear is done with a 1/4" flat end while the radius is a 1/8" on one test and and 3/32" on the other test.
I am left with some raised bits in the middle of narrows that the ball nose doesn't get. I can cheat this material away by running multiple roughing passes with the ball end but now it's doing unnecessary passes along the wide open areas
I know I can use REST machining with an 1/8" endmill before running the ball nose through but I'm trying to avoid 1 extra tool change.
Any good tips on getting that material out of there? using the 2 bits ( 1/4" flat and 1/4" ball nose) for test 1 and (1/4" flat and 3/16" ball)test 2.
Thank you.
