Left open pocket gets milled correctly, right open pocket leaving stock on it's floor
FrodoLoggins
Advisor Advisor
FrodoLoggins
Screen Shot 2021-12-16 at 12.58.20 PM.pngScreen Shot 2021-12-16 at 12.59.00 PM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Joshua.Aigen
Hi @FrodoLoggins, I think you found a bug, maybe @seth.madore can confirm. If it's important to keep your work moving I simply made two 2D contours for each side and the toolpath worked as expected.
Joshua Aigen
Workshop Supervisor
FrodoLoggins
Much appreciated. But I only post questions/possible bugs here. So going further no reason to waste your time on me. I usually have workarounds figured out before I even post here.
engineguy
@FrodoLoggins
@Joshua.Aigen
Yes, a bug but easily worked through, simply select the whole shape and then contain the toolpath with the Stock Contours and set the Bottom Height to the surface to be machined, very quick and easy but shouldn`t have to do it 😞 😞 😞
seth.madore
Yeah, it's a bug, one that I'm 99% certain has been logged. I'll try to dig up a similar ticket and add this part to it
Seth Madore
