Lead In weird movement
Hi everyone,
Something weird happened today. I started with a 2d Adaptive Clearing op and then created a derived operation (2d contour) from the 2d adaptive, but now the lead in acts weird... Lead In and Lead Out are set to the same values. I don't get the problem when creating a 2d contour from scratch.
I added a f3z file. Maybe it's something I overlooked but I don't believe that.
Looking forward to hear from you people.
Sincerely,
Coert
Richard.stubley
Hi @Anonymous,
When you turn on cutter compensation we have to do this in a set way (It can only be applied in a straight move. in the plane of the comp)
However when we turn it off we are not under the same limitations.
This is the main reason for the difference between the 2. The lead in we are carefully turning cutter comp on, the lead out we can turn it off as we retract.
Richard Stubley
Product Manager - Fusion Mechanical Design
