Lead-in has same feedrate as plunge?
FrodoLoggins
Advisor Advisor
Message 1 of 9
FrodoLoggins
Shouldn't the tool plunge down at 50IPM and then lead in at 5IPM? Instead the tool leads in at 50IPM:Screenshot 2024-11-14 at 11.30.51 AM.png
Screenshot 2024-11-14 at 11.32.07 AM.pngScreenshot 2024-11-14 at 11.32.34 AM.pngScreenshot 2024-11-14 at 11.32.42 AM.pngScreenshot 2024-11-14 at 11.32.49 AM.pngScreenshot 2024-11-14 at 11.32.59 AM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Replies (8)
Message 2 of 9
DarthBane55
I think this is the ramp feedrate, but when you simulate and go to the details tab what does it say, lead-in?
Message 3 of 9
FrodoLoggins
Fusion calls it a plunge:
Even though it's not plunging but leading in.
Message 4 of 9
DarthBane55
Red moves are plunge or ramp, yours is plunge, it's a vertical line followed by a vertical radius, and your feed is at 50 for plunge and ramp, so this is correct behavior it would seem.  Your feed height is 0.1" above model, so it plunges, exactly like you instructed it to.
Message 5 of 9
FrodoLoggins
If the tool isn't plunging the tool should not be moving at a plunge feedrate. Simple as that.
An arc perpendicular to the floor is a lead-in, not a plunge and not a ramp.
If I lower my feed height that doesn't stop the tool ramming into the stock:
Screenshot 2024-11-15 at 9.45.27 AM.pngScreenshot 2024-11-15 at 9.46.15 AM.png
Message 6 of 9
DarthBane55
It's not really as simple as that hehe.  If it's a red move, it's either plunge or ramp.  If you want that arc to be a lead-in, you need to change your feed height to be lower, and the vertical arc will become green and feed at lead-in feed.  But because your feed height is higher, it considers it a plunge move.
Message 7 of 9
FrodoLoggins
I can make my feed height only a thou above the bottom height that arc is still 50IPM. And I get a warning about the feed height being too low. Should I try lower than that?
Message 8 of 9
DarthBane55
haha, I'm starting to feel the sarcasm.  I'll step out.
Message 9 of 9
FrodoLoggins
Nope I literally set my feed height to .001" above the bottom height. Fusion still treat a lead in arc as a plunge
