Laser cutting with angle
danielND6TD
danielND6TD
Hello.
Is it possible to laser cut with an angle other than 90º, that is, in 3D, using Fusion360?
For example:
https://www.youtube.com/watch?v=NCRfSJmZMmY
Thanks!
seth.madore
While Fusion doesn't yet allow for Tool Orientation to be used with the 2D Cutting tab, there are ways around this limitation. However, it will require a few post edits..
Use a small endmill and 2D Contour.
A list of very capable post process edit companies are HERE
Seth Madore
