kernal error with turning canned cycle and stock allowances
dave_
Message 1 of 14
dave_
Hi I have a problem with turning. When trying to use vertical pass i get a "Internal CAM kernel error" when canned cycles are turned on. Any idea why or who or where do i ask about this problem?
The second problem is an error withe X and Z allowances. for what ever reason if you set these different the there is an message saying that it is not supported. this to me makes no sense. canned cycles are able to support different material allowances!
also I am not able to up load a fusion file on here any more??
Any help would be great.
Replies (13)
Message 2 of 14
akash.kamoolkar
@dave_
Not sure why you can't load a fusion file here, many people are doing it, in fact I was going to ask you to attach the sample file for your cam kernel issue.
We have already implemented variable X and Z finish allowances for canned cycles and this feature will be released in an upcoming update.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Message 3 of 14
dave_
Hi hope it up loads now i think it may have been the way the file is named (housing v5.f3z)
Message 4 of 14
akash.kamoolkar
Still not there, you can email it to me at akash dot kamoolkar at autodesk.com
Akash Kamoolkar
Akash Kamoolkar
Message 5 of 14
dave_
maybe this works
Message 6 of 14
akash.kamoolkar
@dave_
Thanks, that worked. We've already fixed this issue for an upcoming update.
Akash Kamoolkar
Akash Kamoolkar
Message 7 of 14
dave_
OK thanks so the issue with vertical canned cycle and the X and Z allowance should be fixed for the next update? also it would be nice if canned cycles would work for the turn facing operation.
Message 8 of 14
akash.kamoolkar
@dave_
Corporate policy disallows me from telling you exactly when these fixes will be released so unfortunately all i can tell you is they will both be released in an "upcoming" update.
Akash Kamoolkar
Akash Kamoolkar
Message 9 of 14
dave_
Thanks no problem as long as they are getting dealt with. thanks for your help!
Message 10 of 14
akash.kamoolkar
@dave_
Both these issues have been fixed in the latest Fusion update.
Akash Kamoolkar
Akash Kamoolkar
Message 11 of 14
rwagen
Thank you very much for finally implementing this!
It has been promised us while buying HSMworks > 5 years ago.
It is really usefull. Better late than never.
Message 12 of 14
rwagen
I tested in HSMworks latest 2020sp2 but I could not find turning canned cycles.
When will this be implemented in Solidworks?
Message 13 of 14
akash.kamoolkar
Unfortunately there is no plan currently to add the new turn profiling strategies to HSMWorks.
Akash Kamoolkar
Akash Kamoolkar
Message 14 of 14
rwagen
Very dissapointing. We bought HSMworks because of Solidworks.
I guess we should stop with Autodesk as it makes no sense anymore.
Also I tested a very simple part and it crashed into the material when
using correction in machine. I sent it to my VAR.
I try that same part in Fusion if it won't crash there.
Never have these problems with the most complex parts in Solidcam.
