Keep tool down
Keep tool down
joensolutions
Observer Observer
Keep tool down
joensolutions
Observer
Observer
Hello
Has anyone ideas how I can keep tool down and cut pieces using 2d contour.
I am using tool 4mm and gap between pieces is 4mm. I want cut pieces just as fast as possible without any extra Z moves.  But I cannot jump from one piece to another without Z move. Keep Tool down not work.
Br Ville
seth.madore
First off; would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Secondly; "common line cutting" isn't something that the 2D Contour toolpath is capable of. If you have multiple contours, it will (if possible) create a toolpath for each one of them.
Based on your image above, how do you plan on cutting out that dogbone shaped cutout and separate the adjacent part, using one pass?
Seth Madore
joensolutions
Observer
Observer
Hello Here is the file
seth.madore
There's no conceivable way to get this all cut out in one continuous cut, or link safely between passes. A retract is needed to reposition as required.
Seth Madore
joensolutions
Observer
Observer
Hello
Ok. Thanks about your answer.
