July 2025 Post Processor and Manufacturing Assets What's New
andrea.amilo
Community Manager Community Manager
Message 1 of 1
andrea.amilo
Post Processor and Manufacturing Assets What’s New
Looking for the most recent Fusion Post Processors along with a variety of new impressive Manufacturing Assets? Look no further!
We are dedicated to consistently providing updates and improvements to our diverse range of open-source tools: Post Processors and various Manufacturing Assets, all of which are available for free. These updates can sometimes be overshadowed by other enhancements or major feature releases. This post aims to update you on all the newly added or improved assets.
This post will get refreshed with notable updates as they’re released, and you can click each hyperlink to go to the mentioned post. As always, you can find the latest in our post processor offering on the Online Post Library where you can search by vendor, type, or name, and see any recent changes to each post processor.
MAIN CONTENTS
  1. New Post Processors
  2. Improved Post Processors
  3. New Machines
  4. Improved Machines
  5. Improved Print Settings
  6. Tools and Tool Holders
  7. Post Processor Ideas
Milling Post Processors
Fagor 8065
Added generic milling post processor for FAGOR controls, such as 8058/8060/8065/8070, with an option for the easyplane function.
Kitamura Arumatik
Added generic milling post processor for machines with Kitamura Arumatik controls.
We are always working to keep post processors up to date with new technologies. This is a summary of the main improvements made to post processors already in the library.
Generic Post Processors
-Added support for machining type Polar in multiple generic milling post processors.
-Added support for machining type Polar in multiple generic millturn post processors.
-Fixed polarCycleExpandMode setting to be backwards compatible with older post kernel versions.
DMS Router with Fagor 8065 Control
Updated DMS router fagor 8065 post to use shared content across post processors
Added the 'Use G68.2' post property to several Fanuc based post processors.
Haas, Haas EC, Haas Next Generation Control, Haas Inspection, Haas Next Generation Control Inspection, Haas Desktop Mill, Haas UMC-750
Fixed incorrect feed mode output when 'useG95forTapping' property is enabled in Haas post processors.
Hurco, Hurco Inspection
Fixed missing Z axis retract when using head configuration machines in Huro post processors.
Mitsubishi, ShopSabre IS-M
Resolved the missing TCP cancellation command issue between operations in Mitsubishi based post processors.
Osai
Fixed issue with Single Line Retract for OSAI Post processor.
3. New Machines
The Machine Library lets you manage your machine tools by using Machine Configurations to define your available machines and resources. These configurations can automate the settings in your Job Setup.
There are many Machine Configurations available in the standard library.
Milling Machines
You will have available configuration files for some of the leading machine manufacturers:
MX 10 M
The following configuration files do not contain any 3D model, but have all the settings required to optimize your postprocessor for these specific machines:
Kitamura Mycenter-4XV
Kitamura Mycenter-HX400iG500
Kitamura Mytrunnion-4G
The easiest way to get started, is to copy an existing configuration that matches some of the characteristics of your machine.
Milling Machines
Autodesk Generic 5-axis (AB Table-Head)
Autodesk Generic 5-axis (AC Table-Table)
Autodesk Generic 5-axis (BC Table-Table)
Additive Machines
One Click Metal MPRINT LAB
MPBF.pngUpdated EOS EBPAs print settings.
Renishaw RenAM500Q Inconel In718-Q M 60 micron
Renishaw RenAM500Q Inconel In718-Q S 60 micron
Renishaw RenAM500Q Aluminium AlSi10Mg-B60-Q S 60 micron
Renishaw RenAM500Q Aluminium AlSi10Mg-C60-Q S 60 micron
 Updated "Layer 1 Extruder Temp" settings in all FFF print settings.
The Tool Library lets you manage tools for Milling, Turning, Cutting (waterjet, laser & plasma), Touch Probes and Holders. The Tool Library lets you manage libraries of predefined tools and project documents.
Successfully streamlined our tool libraries by removing outdated ones.
To make our library more varied and complete, we are always working on new post processors. Some of them still need more testing before being released in the public library. Every new Beta post processor is announced in the Idea Station, you can find all of them in the Post Processor Idea Station .
Please note that if you choose to use one of these post processors, you assume all inherent risk in using it and we ask that you proceed with caution.
That being said, we are looking forward to get your feedback!
Click here to see the previous What’s New release.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
Replies (0)
