Jerky adaptive re-positioning moves
Hello All,
I've tried a ton of recommended settings for tolerance and smoothing but none seem to fix this issue i've been having with my adaptive strategy re-positioning moves. the actual cutting moves are great and very smooth, but the re-position moves seem to always have small straight line segments that cause the machine to be jerky.
I am using linuxcnc with G64 path blending set also with the tolerance in fusion, i've tried the machine tolerance value at many settings and non seem to fix this and was hoping someone could tell me if there is a setting to have the re-position moves turned into tangent arcs rather than line segments. I don't see any reason why these below could not be made into straight lines with tangent arcs in the tool path planner? but i also don't see any settings to address it. any help is greatly appreciated! currently for best results i'm using tolerance at 0.0005 and smoothing at 0.001. i am attaching a video that should start at the correct position to show the stuttering in these moves that actually make the machine shake. and a points image showing the offending moves.
Thanks in advance for any thoughts on how to address!
Chris
video should start at 3:10 mark listen and watch the doors on the re-positioning adaptive moves...
https://youtu.be/LDMKMx2aO5E?t=190
