I am experiencing an issue when using the 5-axis geodesic strategy on a Hurco machine equipped with a rotary table.
I need to generate a toolpath on the opposite side of the current one (as shown in the attached image), but I am unable to force Fusion to switch the machining side.
The current toolpath is not usable, as the machine reaches its travel limits due to spatial constraints.
I would like to point out that in the Machine Builder, the head tilt preference is correctly set to negative. However, Fusion does not seem to respect this setting when using the geodesic strategy, unlike the 3+2 strategies, which correctly generate the toolpath on the intended side.
I would like to know whether this issue is due to an incorrect setting in the strategies on my part, or if it is a limitation or bug in Fusion.
I would also like to ask whether this issue is exclusively related to Fusion, or if it could be caused by the post processor loaded in the machine configuration.
The project is attached for analysis.
Thank you for your attention.
Best regards.
