Is Tool Orientation possible by tilting the milling head?
I have a Sherline Mill with a multi-angle mill head, so I am able to tilt it in several different angles then lock it down manually at a given angle before running the OP (not a rotary table, the bed is stationary). My question is can F360 understand that I'm not rotating the part but I have just reoriented the milling head (and therefor the WCS) at a funny angle so that I can mill a slope into flat stock.
When I post with a 3axis post, it says tool orientation not supported, which I totally get.
When I post with a 4axis post it wants to rotate the B axis by 3 degrees, then machine on the flat XY origin, which is not what I want.
How can I tell F360 that the WCS is at a different angle from the stock because the milling head is manually tilted -3 degrees on the Y Axis, not by rotating the actual part? Kind of like manual 5 axis machining I guess.
I am using a modified LinuxCNC (EMC2) post processor to allow A-Axis.
I'm hoping this is something obvious...
