Is there a way to get rid of or move the Multiaxis tab when creating an operation?
jesseatbettercnc
jesseatbettercnc
The latest update has thrown me off where I'm constantly clicking on the multi-axis tab instead of the geometry tab. Is there a way to just turn off the multi axis tab or move it when creating an operation?
I'm taking a leap here and am going to bet that the vast majority of Fusion users don't use Multi-axis for +90% of their operations. Why would you move that tab further to the left assuming tabs are intended to be sorted by high priority left to right? This seems like a very strange UI decision.
HughesTooling
I don't like this either. @seth.madore any chance we could have a setting for 3 axis only and hide this tab?
Mark Hughes
Owner, Hughes Tooling
seth.madore
The Multi-Axis tab is going to remain where it is, and this is an intentional change. Moving it to the second tab strengthens the "left to right" workflow.
1) Select a tool
2) Define whether it's a 3, 4, or 5 axis tab or even just Tool Orientation
3) Select your contours/boundaries.
The prior workflow was broken, to be honest. You'd have to go to the 4th tab to enable 5 axis, back to the second to modify some new fields that became visible, over to the third to adjust your heights, over to the 5th to adjust some other fields. This presents it in a linear fashion for all.
It's a matter of muscle memory and it will take some time to adjust
Seth Madore
