Is there a better way to do this? (4th axis circular milling)
I struggled a bit with generating a circular groove on a cylinder, but with some advice here, found that I could generate the form by not going a full 360°. this prevented the "Can't unwind cyclic geometry" error. I then thought that I had the machining figured out by using 2D Adaptive Clearing. This resulted in a toolpath on the surface, but not to depth. I then added a negative value for the depth and got the machining to go to the proper depth. MY question is, is there a better way to approach this problem? I'd like to be able to machine the profile without having to leave that little sliver of material, but am more interested in a good result in the profile itself. My Screencast omits the editing of the toolpath to create multiple depths but shows my thinking on accomplishing the process.(One could also simply use a single depth, but that would be a personal / material / cutter preference).
paul.clauss
Hi @Anonymous
Thanks for posting! This is a known issue for our development team, who are working to remedy it.
I like the work-around that was presented on the other thread and here! Another potential workaround could be to draw a sketch on a flat plane and then wrap its toolpath around the cylinder, as illustrated in the screencast below:
Using this technique should allow you to avoid leaving the small sliver of material! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Thank you Paul. The one thing that I have noticed about FUSION 360 is that the development team is very responsive and the online support is extremely helpful. I hope that this gets addressed in the near future. I'll give that process a try and post back here what I find out.
Thanks again
Hey,
What I've noticed is to do a wrap tool path without leaving that wall, is to create your part with the original origin of the cylinder on the y axis. So if the y axis is your cylinder the wrap tool path works.
I have no idea why, but that's what I figured out.
