Is it possible to eliminate extra retracts in Bore operations for large holes?
Eric_Evans_a_GiroDisc_com
Trying to make holes of various diameters with one tool; some holes may require one, two or three stepovers to reach final size.
If Multiple Passes is enabled the tool will bore a first pass, fully retract from the hole, stepover, bore a second pass, fully retract, stepover, etc...
As an alternative I can set it to have a finishing pass with a large stepover, this will bore in, step out, and cut a larger diameter.  This works on smaller holes but fails once I need more than one stepover.
I have Keep Tool Down checked in the linking tab.
While were at it; Multiple spring passes, and independent control of finish S&F would be nice features to add to the Bore operation.
My other option is to use 2D Pocket with a helical entry but the entry is offset from the centerline of the hole which technically works (but I don't think it helps with cylindricity of the hole) and I also have to pick every...
single...
hole...
rather than auto selecting same diameter.  That is not acceptable in this situation.
DarthBane55
I totally see your point, I think "bore" is lacking a bit.  Ideally, the bore operation would allow us to choose a helix and/or spiral, that would fix all the issues with this cycle.  I can't see a way to fix your particular problem except going to adaptive, but that forces you to pick each hole, which you said is not acceptable.
I have never felt the need to do multiple helix in 1 hole!  Once you do the initial helix, why would anyone helix once more at a bigger diameter!  What you want to do is after the 1st helix, stay down and do a spiral out to get to the bigger diameter, just like adaptive does perfectly, except have to pick each one.
Alas, that is pretty typical for Fusion, seems like the majority of the updates/new features are just done by software people because they can, as opposed to them having any sort of actual benefit to people making things 🙄
programming2C78B
ive asked this before. Just needs a "keep tool down" toggle.
Please click "Accept Solution" if what I wrote solved your issue!
CRANDALLPRECISION
if you pick it as a drill op and under cycle type pick circular pocket milling it rights a great spiraling pocket program. I don't know why this doesn't get implemented as a regular toolpath.
I had never noticed that before.
Kind of an odd cycle; no cutter comp, no option for finish pass stepover, you have to manually enter the finished hole size, and also doesn't preview correctly without simulation.
That’s correct but if you have a ton of holes it’ll calculate instantly
compared to a 2d dynamic path. I leave stock and come back and finish with
a circular or helix bore for the comp features. It’s basically a canned
cycle to run at points
Crandall Precision Inc.
231-775-7101
