Is it possible to Copy the intire admin file folder to a local computer?
MachinistJoe
MachinistJoe
We are in the process of converting from Feature Cam to Fusion. No need for the capabilities of Feature Cam(Only 3 Axis machines in shop). I was able to copy and Paste files directly from Feature Cam to a Local folder but am having trouble doing the same with Fusion 360. I found where you can do individual files, but I have large amount of files in Fusion. Is there a faster/better way to do it?
Thanks in Advance for your help!
Joe
Garrett_Wade
If you are moving TO Fusion then you should be able to just log into your account to access any files you need.
Mass exporting isn't possible natively in fusion currently, there is some 3rd party built plug-in options that let you mass export files out of fusion and they honestly work great if you don't have any assemblies that use linked files/components....if you have files like that it creates a huge mess.
MachinistJoe
Thank You was just seeing if there was something I missed. Sound like I will need to move them over individually from Feature Cam to Fusion.
Garrett_Wade
If you are moving some solid files into fusion (uploading them) you can drag a group of files into the upload window to do a mass upload.
