Is fine step down working on 3D pocket.
HughesTooling
Consultant Consultant
HughesTooling
This is what I get with step down and fine step down set to 5mm.
When I set fine step down to 1mm it clears all of that level, just like setting the step down to 1mm. It's not clearing at 5mm then working back up at 1mm intervals.
File attached
Thanks Mark.
Mark Hughes
Owner, Hughes Tooling
jeff.walters
this is not the way the wat it should be working I will get it reported.
Jeff Walters
Senior Support Engineer, CAM
HughesTooling
Could you also take a look at what happens if you set Ramp to Plunge out side of stock. Also noticed on something like this setting 2 entry points doesn't seem to work very well.
Updated File attached.
Mark
Mark Hughes
