Invalidated toolpaths
cage86U75ZP
Message 1 of 15
cage86U75ZP
Hello!
All of a sudden I cant seem to create any new toolpaths!
Use Fusion 360 everyday, everything was fine yesterday, but as of this morning nothing seems to work, even very basic stuff.
Even copying a toolpath and making small adjustments has the same outcome.
Here is a small section of an error message, the same tool is used in other parts of the job no problem.
Invalidated: Tool
Invalidated: Tool
Invalidated: Invalidation due to different value for parameter 'tool_type' with level 7.
Invalidation due to different value for parameter 'tool_number' with level 2.
Invalidation due to different value for parameter 'tool_diameterOffset' with level 2.
Anyone else having similar issues? I don't think I am doing anything different to normal!
Replies (14)
Message 2 of 15
seth.madore
Can you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 15
cage86U75ZP
Hi Seth, thanks for the speedy reply!
Can I PM it to you? Don't want to post a customer part on the forum if I don't have to!!
Message 4 of 15
seth.madore
Email it to me: seth dot madore at autodesk dot com
Reference this thread so I will know the context 🙂
Seth Madore
Message 5 of 15
cage86U75ZP
Also, I just tried it on 3 completeyl different parts, all seem to have the same problem
Message 6 of 15
cage86U75ZP
Should I still send it even tho it's doing it on every different part I try?
Message 7 of 15
cage86U75ZP
Also, same problem even on a brand new, super simple model with new tools etc
Message 8 of 15
seth.madore
Is it possible you have any non-ascii characters in the tool name? Such as the degree or diameter symbol, õ, or any such non-english text?
Seth Madore
Message 9 of 15
cage86U75ZP
I dont have any information in the tool name, I never use that feature!
Message 10 of 15
seth.madore
Yes please. Also, Fusion has a ScreenCast option, could you use it to show me what you're seeing?
Are you on Mac or PC?
Seth Madore
Message 11 of 15
cage86U75ZP
I'm on PC, downloading screencast now
Message 12 of 15
cage86U75ZP
I have uploaded a screencast, let me know if you want more!
Message 13 of 15
cage86U75ZP
I have come home and it works on my home PC! Maybe that will help?
Message 14 of 15
seth.madore
I'm not seeing a ScreenCast....
I did receive your sample file, but it regenerated fine. What happens when you select the Setup and CTRL+G?
Seth Madore
Message 15 of 15
cage86U75ZP
Went back into work and it all seems to be up and running.
Thanks for your help!
