internalcam error!
internalcam error!
CuttingEdgeManufacturing
internalcam error!
Hey guys, i just copied this project for a iteration, this is the originial file, all i did was change the file name, and now i have a internal cam error on "op 2" Position 4 subfolder.
this program is for a positional 4th axis on a haas tm3p. but i dont think that really matters in this case..
the copied version works just fine. all i did was move my version back to this morning to undo some changes i made today and changed the file name so i could have 1 version with todays changes.
naturally this is the one i need first.
seems to be something to do with the 2d contour, multiple depths?
seth.madore
I've been looking at your file and cannot get that toolpath to fail 🤔
Seth Madore
i did a halfways fix, but getting rid of the multiple depths, and instead did roughing passes..
then got the same error on the same file on a new operation for another fixture. same problem. multiple depths is the issue for me..
crappy thing is this one was with a .125" endmill that i now have to try and slot with instead of tiny stepdown.
seth.madore
I know I'm asking a lot of your time on this, but could you recreate the issue in a simple piece so we can work through the data quicker? Handling the .f3z file along with your 4th axis becomes rather unwieldy across iterations
Seth Madore
