Increasing feed 10 fold only shaves off 2 seconds of cycle time?
FrodoLoggins
Advisor Advisor
FrodoLoggins
So for this 2d contour a feedrate of 60IPM results in a cycle time of 4:52:
Screenshot 2023-06-23 at 2.35.10 PM.pngScreenshot 2023-06-23 at 2.35.19 PM.png
Changing the feedrate to 600IPM the cycle time is 4:50:
Screenshot 2023-06-23 at 2.35.38 PM.pngScreenshot 2023-06-23 at 2.40.30 PM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
FrodoLoggins
EDIT: Also using the Laguna post the feedrate was half speed. I posted another toolpath (a copy of the problematic toolpath in the previous post) that was programmed to be 80IPM but a feedrate of 1016mmPM (40IPM) was posted:
All other toolpaths post with correct feedrates.
Laguna post: https://cam.autodesk.com/posts/post.php?name=laguna
seth.madore
For your first issue, that's because you've overridden the Finish feedrate, which is found on the passes tab. Bumping up the feedrates in the Tool section has no impact on your F30. finish feedrate.
Changing everything to F600. yields this:
Seth Madore
seth.madore
For your Laguna feedrate issue, I would hope that it's plunging at 40ipm, since that's what you've set it for...
Seth Madore
