incorrect rendering of the toolpath in the simulation.
Tomas_V_cz
Message 1 of 11
Tomas_V_cz
We noticed that some correction arrivals are incorrectly rendered in the Simulation. Departures from the correction are fine, but the approach is not tangential to the radius, but at an angle.
The code from the post processor is fine
I made a simple part with a slot where I demonstrated the strange behavior.
Replies (10)
Message 2 of 11
seth.madore
Are you using In Control compensation?
Seth Madore
Message 3 of 11
Tomas_V_cz
Najezd5.pngYes
Message 4 of 11
seth.madore
Yeah, this is a known limitation in our Simulation. As you note, the toolpath graphics (out of Simulation) are correct as is the posted code.
Seth Madore
Message 5 of 11
Tomas_V_cz
I did notice the setting and when I disable the option as shown the toolpath is fine after that.Najezd6.pngNajezd7.png
Is it better to leave this option disabled? Or in other situations is it better to have this option turned on?
Message 6 of 11
seth.madore
Could I get your sample file to double check my prior statement?
Seth Madore
Message 7 of 11
Tomas_V_cz
OK
It is a test file-2 operation.
Message 8 of 11
seth.madore
Ok, my prior statement was incorrect (based on misunderstanding of things).
The In Control Radius Compensation "Optional Feature" is an improved algorithm to calculate the toolpath.
What is shown "in canvas" is what is fed to the controller. What is shown in Simulation is the path that the tool will take.
In this case, what you are seeing in Simulation is not technically correct (with the In Control Comp turned off), what you see with it on IS correct.
Seth Madore
Message 9 of 11
Tomas_V_cz
I'm not sure I understood your answer well. But my conclusions are this:
 Turning on "In-control radius compensation" has no effect on the resulting NC program. Switching off/on will only take effect in simulation mode (as seen in the picture from Friday with the question marks (???) next to the arrow).
 The tool moves only in the X axis and moves perpendicular to the part. Rendering in the simulation (when "In-control radius compensation" is turned on) is incorrect.
thank you very much
Message 10 of 11
seth.madore
Not quite. What is being displayed in the Simulation is the compensated move as Fusion calculates it and what the machine should also be doing in it's motion. (as the controller is also offsetting the toolpath by the radius of the tool)
You can see this in action by playing with the Lead-In/Out settings. Personally, I prefer to have an arc lead-in/out like this:
Which would result in a simulated toolpath of this:
Seth Madore
Message 11 of 11
Tomas_V_cz
Yes, it is possible. But in my specific settings "perpendicular" is turned on (I don't know how it is in the English version) - image.Kolme.pngKolme-2.png
