Hi
Ive been using fusion 360 for over a year now and have recently started using the cam machining , I have found that the machining times stated are not correct. I have found this mainly in the drilling operations where each operation has in unrealistic machining time .
This was using the default 30m per minute 100% .
I have also activated the Manufacture Preview in Preferences and created a machine with all feeds given a rapid traverse value for all axis.
Please can you advise if there is something I am doing wrong or is there a work around to solve this problem.
Regards Graeme scott
