Incomplete / Incorrect Cuts
Workflow: Fusion 360 / UGS / GRBL Post / Magic Fairy Dust / XCarve 750mm (newer version) with X-Controller / Dewalt 611
I've been cutting out some Dice boxes and this is my third box. I've been doing a Save As on each box and modifying the initials and custom front design. The first two boxes went exactly as all simulations shown. However, this third box has deviated from the simulations on two separate operations and I cannot figure out why. One of which almost ruined the box. Heavy sanding saved it.
Since this is a double sided cut, I use a peg system for flipping. I drill holes placed equidistant from the center and its worked pretty well. Due to the depth of the cut (about 7/8") I cut a small pocket large enough for my Dewalt chuck to fit into as a precaution. On this cut, the machine decided to not cut the entire pocket out despite 3 different simulations showing it should. Two of the pockets it only did one spiral and the other two pockets it performed all but the last spiral.
Here is what happened next to a correct version. The bottom of the wood cutout picture corresponds to the left side of the above pictures.
Note the holes on the top right are smaller than the top left (by one spiral) and the bottom right holes only performed one spiral.
The next thing was a major issue as it damaged the box. When cutting out the box, I perform a contour cut with multiple depths including tabs. One one of the first passes, the machine seemed to go to the wrong point for one of the corners. It seemed to choose a point closer to the center causing it to slice out a section. Picture worth a thousand words:
I have not updated my GRBL controller or UGS between the different boxes I've cut. The only possible change is Fusion 360. But with the simulations showing exactly as I expect, i just don't know where the issue may lie. I've attached the NC files of the operations in question (untested by themselves, I grouped several operations for the actual cut), as well as the full box design. Any ideas would be greatly appreciated.
