@Anonymous
It is somewhere in the selection of the contours, I just re-selected them and it works OK (week 1-MOD.f3d), I also did a file with the "Preserve Order" enabled and that seems to work fine (week 1-MOD-2 .f3d), both files attached for your inspection, I may well have missed something else, looked at it too long 🙂 🙂 🙂
2D Profile is at best "BUGGY" so as I have found in the past with a lot of Contours that are not easily "Toolpath Patterned" there are issues and careful selection in the best order possible is usually the way to go 🙂 🙂 🙂
@ChristopherMarion
Chris, nice job, and I agree that the the whole of the 2D Profile needs looking at as soon as possible 🙂
Like you I tried different things and got weird results, one was that just opening the original file and enabling the "Preserve Order" (which often clears things in 2D Profile) the offending triangle worked fine but the bottom triangle went the same way with a tiny toolpath just as you found on the side one, very weird indeed, so not I think specific to that triangle?? 😞 😞 😞
Anyway, here is what I have, it was in the end an easy fix, just dump all the original selection, reselect them all in a "proper" order and all is good 🙂 🙂 🙂
I should have done that in the first place, we live and learn, the simplest option is usually the best 🙂 🙂 🙂
