I want to process using a chamfer tool. Is there a way to process with multiple depths?
Hi
You can do this with 2D contour and defining your chamfer mill as a Tapered endmill
If your chamfer mill has a sharp point you cannot give it a tip value of 0, so I just put in 0.01mm
See attached example
I want to make a 6-pie end mill. If you set the tool diameter to 0.01, you cannot set the circle part.
Hi
To also achieve multiple radial passes using the tapered endmill, you will have to have a number of toolpaths with reducing amounts of Radial Stock to leave.
You can put them in a folder to Keep them neater.
See attached
Thanks, it's resolved!
