I need a shove in the right direction, acquired Colchester 220M with Fanuc 21i-tb
methods2
Message 1 of 8
methods2
My work has acquired a Colchester 220M with a Fanuc 21i-tb controller
how do I go about getting a post so i can do my operations in Fusion.
where do I even start?
is there someone i can hire to create a post that will work with my machine?
Replies (7)
Message 2 of 8
a.laasW8M6T
Hi
You can in the first instance try the Fanuc turning post from the Fusion library.
If you need customization you can find approved partners here:
https://www.autodesk.com/nz/support/partners?services=Post%20Processor
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 8
methods2
I should have mentioned
this machine has live axial and radial tooling
so the post would need to be a MILL /TURN
Message 4 of 8
a.laasW8M6T
A lot of people use the Doosan one but that's a 31i
Generally the first step in determining whether a post will work is having a good understanding of all the required code formatting/which G codes/M codes the machine uses, or having known good programs to compare the output to.
sometimes all that needed is some simple edits, other times there may be some more complicated changes required.
Working with an Autodesk partner is the most reliable way to get a good working post if you are not comfortable making edits yourself
Andrew Laas
Message 5 of 8
methods2
OK
I used the doosan post and it seems to be working for outputting my code ( have not tried in machine yet)
here is a sample of a live tool doing a spot drill in the end of the material
most of it makes sense to me with the exception of the M89 at the end of the drill cycle line and two lines below it
this section of the program  is supposed to drill two holes in the end of the part 1.25 inches across from each other
N5(DRILL2 7)
G0 G28 U0. V0.
G28 W0.
M5 P11
G54
G98 G17 M35
M90
G0 G28 H0.
T0808
G97 S2000 M3 P12
G0 Z0.6
X1.25 Y0. C-180.
G0 Z0.2
G83 C-180. Z-0.13 R0. P100 F40. M89
M90
C0. M89
G80
G0 Z0.6
M5 P12
M90
G28 U0. V0.
G28 W0.
M1
Message 6 of 8
methods2
I cant see how this is drilling two holes unless the M89 is used to repeat the drill cycle at C0. since the first one is at C-180.
Message 7 of 8
a.laasW8M6T
Hi
G83 is MODAL so it will perform a drilling cycle at every block with a XYZC coordinate until G80 is called
The M89 in this case is the C axis brake ON, M90 is C axis brake OFF
Andrew Laas
Message 8 of 8
methods2
Thank you
That clears up a lot of things
I can see myself moving forward with this using Fusion to create the program  and maybe even modifying the post to suit my needs
