I always have trouble with parallel and cant suss this one.
boyd.sofield
boyd.sofield
Would it be a nice operation if we can carry out a parallel op without having to extend faces to stop the tool from dropping down each side in non necessary tool paths? I guess what I am saying is its never easy all the time. Even just an extension off a plane would be a good start.
Regardless. This part as simple as it is has taken a lot of work as it sticks out from my vice a LONG way. I am still working on the operations and am being super cautious to take small bites, starting at the very extent to retain some rigidity as the stock dissappears.
This post though I cant understand the last parallel operation seems to miss a portion of the surface leaving a triangle of stock. I dont know why because its not making sense, need a bit of help? Image attached is what I get in simulation it just totally misses a section. Weird? Yes
Oh, another question on parallel. I have a surface in the Y direction cutting in the X direction. I want the tool path to start and work in the negative direction towards the vice. This op starts at the vice and horizontal moves away from the vice. I cant work out how to change that? I tried a preferred entry point, Fusion just ignored it. Hmmmm
a.laasW8M6T
Hi
To change the Direction you can just flip it 180 degrees in the pass direction
I regenerated the toolpath without changing anything and it machines the whole surface
I'm not sure why it was missing bits for you
regen after importing
Direction flipped 180
Andrew Laas
Senior Machinist, Scott Automation
programming2C78B
Use this tool on your top curved face, and use an offset distance of 0.
then use this one on THE NEW BODY's edges by ~1/4 your ballnose diameter.
before:
after
You then select this new Body in your toolpath under "Model"
Please click "Accept Solution" if what I wrote solved your issue!
boyd.sofield
Hi guys. Thanks for this I have found this part REALLY challenging! Have managed to get the tool paths sussed, now I need to go through somehow to stop the tool from plunging or crashing into the stock on a few of these ops. But I will eventually.... lol.
Best regards
programming2C78B
You should be roughing everything out with a regular endmill and 3D adaptive beforehand.
