Hurco post processor not outputting workoffset in NC file
Regardless of what WCS offset I enter, the outputted NC file does not contain any work offsets.
Using:
Accepted solutions (3)
Arun.rs
Hi @Anonymous
Thanks for raising your concern via Forum.
Open post file in a 'Visual Studio Code' or 'Notepad++' to do the required modifications.
1. Got to line number 852 and 873 , remove ' /* ' and  ' */ ' from these lines.
  // wcs
  if (insertToolCall) { // force work offset when changing tool
    currentWorkOffset = undefined;
  var workOffset = currentSection.workOffset;
  if (workOffset == 0) {
    warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
    workOffset = 1;
  if (workOffset > 0) {
    if (workOffset > 6) {
      error(localize("Work offset out of range."));
      return;
    } else {
      if (workOffset != currentWorkOffset) {
        writeBlock(gFormat.format(53 + workOffset)); // G54->G59
        currentWorkOffset = workOffset;
Save the file and check the output.
Regards
Arun.RS
Technical Consultant - Post Processor
AchimN
Removed duplicated answer
Achim.N
Principal Technology Consultant
Thank you! That worked!
Is there a solution to use WCS beyond G59?  i.e. extended work offsets?
Arun.rs
HI @Anonymous
Yes you can extend the work offset by adding some condition in post.
1. Replace the below stuff from this :
    workOffset = 1;
      return;
    } else {
To This :
      var p = workOffset - 6; // 1->...
      if (p > 300) {
        return;
      } else {
          writeBlock(gFormat.format(54.1), "P" + p); // G54.1P
    } else {
Hope this helps !
Regards
Arun.RS
You're awesome @Arun.rs
