I'm trying to machine the below feature in Plexiglass (see marking in the drawing below).
This is designed as a chamfer. The angle is 30°, and the height is 3 mm. I have included my f3d file in this post.
I'm using a Chamfer Mill with a diameter of 3mm and a taper angle of 30°. This results in a flute length of 2.6mm, which means that I would expect to see several passes. Because I don't want to go to fast, I would even prefer to use passes with a depth of 0.4mm (I'm normally using this when cutting in my Plexiglass). But the "2D Chamfer" seems not to have any option to enter "multiple passes", so I have the strong feeling that, although the name indicates "chamfer", I'm using the wrong tool or method.
If I look at the simulation, there is only one pass towards the lower edge (and yes, that's the edge I selected). But because the flute length is only 2.6, and I'm even having an offset of 0.2mm, it's logic that I seem to miss a part that is not cut (see marking in the drawing below).
I'm sure I'm doing it wrong. Can somebody give me some hints? Thanks!
