How to surface this remaining material?
programming2C78B
Advisor Advisor
programming2C78B
Too far down to go in with a flat end mill and Rest machining on a contour. How can I get Parallel to surface just this remaining section - ideally without drawing my own patches or bodies to drive the selection?
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
A) It's not 100% clear to me which surface you are referring to
B) Everything is just so much easier to control when you have a proper surface/patch to work with 🙂
Seth Madore
programming2C78B
the triangle left over in the corner of the floor.
seth.madore
Having done identical features on some of the parts I've run, I've always opted for sketches to constrain what I need (creating a boundary). It is possible to use Rest Machining and Touch/Avoid to get what you see below, no sketches needed
Seth Madore
programming2C78B
When I tried Rest is gave me empty toolpaths. I never had much luck with surfacing rest to work properly in the past.
programming2C78B
I managed to cheat it to do what I want with 2D contour and rest/roughing passes
leo.castellon
This is a common situation in the machining world, I am surprised someone doesn't have a better algorithm for these situations.
LeoC
