How to prevent tool path being a green line?
Hi Men, I mill say 12 parts on a 3/4 inch 4ft b 4ft ply board. I use scallop, parallel, 2 d contour, morph, I try to put all parts in 2d contour and then REST following ops. I also click no contact in leads and trans.
I use several step downs with each op. IE: I set scallop to .15 bottom, .3 bottom, .45 bottom to .7. In parallel op I am running now part one is milled fine, and then tool stays at depth and goes to next part. Today OK no run thru another part yet I dont want this tool path to run at depth, I want it to retract and then move to next mill.
I dont know how to adjust the movement lines. The line in question is green and it shows in sim that move from one to next part is cutting stock.
Thank you, JR
