How to Multi block macro
nubrandao
nubrandao
Hi, I work with multi small parts, I assembly in a special fixture M10
How do o create multi block for each part? Should I do before starting assembly and export has mesh?
In powershape I usually create a box in center and export has STL, then import in powermill
Looking for a easy way in fusion to build multi block stock
seth.madore
Multi block? Do you mean the stock that would be created for subsequent reuse? Could you share an example of what you're trying to do?
Seth Madore
nubrandao
I need to create  a box with personalized size até the center of each mould inserts(small parts)
Sometimes I have more then 10 parts, I need 10 stocks
S
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
