09:44 AM
Hi All,
I'm cutting sun glass lenses using 5 axis CNC. I make tool path for the left side, and copy the same setting for the right side. I just change the CAD model, in fact just change the geometry to another mirrored part. however, while it seems everything is the same the results are different in practice (I was able to witness that the machine is not using a same tool offset in both left and right machining, but it might not be the only problem). I was not able to find the source of the problem. So I was thinking if there is a way to simply mirror the Gcode or the tool path with respect to YZ plane the problem should solve. I don't know how to do it and I appreciate any help.
