How to measure simulated stock?
Hello, how to measure simulated stock dimension like measuring normal model in the green state below? I try save stock as STL model but the measure tool selection can't select the way it does on normal model.
seth.madore
Measurement of Simulated Stock is not currently possible, unfortunately. You CAN convert the .STL stock into a Brep body, in which case the Measure tool should work.
Seth Madore
