Hey guys,
So I have done this before as a test but now for the life of me I can't figure out what I'm doing wrong this time.
This is going to machine out a slot to fit a specific hinge model into the side of this door. We have a 5 axis CNC machine that we have just started to play around with and wanted to test this out.
Ideally, we would like to lay the doors FLAT on the CNC bed and machine the slots from the side (we could stand them up but for the sake of testing different methods we wanted to try machining these from the side - we will have to elevate the door stock so that the machine head has room to access the slots. This file is simply a test and does not have to include the elevation in the Setup).
I know that this is probably a simple mistake on my end, but does anybody have an idea of what I am doing wrong?
I selected the side of the door under Tool Orientation so that the tool can machine at a 90 degree angle. Then selected 2D Pocket (should I be using 3D pocket instead?). I have tried to tweak the settings but each time I am getting an error telling me that the toolpath is empty.
I seem to have eventually gotten the tool to operate (although like I said my settings are probably a little off) but it seems to be getting a collision error this time and can't figure out why. The Heights are accurate and the "collision" is not really hitting anything.
Just a bit confused.
Many thanks in advance for looking into this again for me,
Mike
