How to configure 4th axis with rotation spindle and fixed table?
contactP4KME
contactP4KME
Dear all, I would like to know how to configure the 4th axis so I can mill using a 4 axis router that as a spindle that can rotate 180 degrees from left to the right? The part doe not move, as neither does the table. It is the spindle that tursn horizontaly. See this video on second 0.25 : https://youtu.be/CaGIDEIynfk . I am testing the "machining extension". Thank you for your help.
brad_francola
Hi.  It sounds like you are trying to setup a machine simulation.  Can you share your machine model and CAM file that you are working with?  That will make it easier to help you.
brad_francola
Here is an example that may be helpful.
contactP4KME
Thank you very much! I'm very sorry for the late reply. Yes that is the idea! Thanks!
