How to auto-select hundreds of oval holes? Pocket Recognition does not work?
johannesJGAKQ
johannesJGAKQ
I am trying to set up a strategy for machining slots in these pre-made extruded profiles that come in 12 meter lengths (around 36 feet..).
The material is 3mm 6082 aluminum, and I am trying to use Fusion to calculate machining time for various machining strategies.
But struggling with even basic pocket recognition for most strategies. 2D pocket does not work. If I use 2D contour with Silhouette recognition, not all holes are identified due to the shape of the profile. Using Pocket Recognition produces empty tool path.
Most other options I tried, like 2D adaptive/3D adaptive produce empty tool path or time out.
Preview shows the slots being identifiedPreview shows the slots being identified
But result is empty tool pathBut result is empty tool path
I have a model body and a stock body defined in my setup. See files attached.
Any idea to what is wrong with my setup?
programming2C78B
can you do one and then simply pattern it?
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
That would be my approach as well. I tried Pocket detection and gave up after 5 minutes of Fusion becoming unresponsive. I'm sure it was running the calculations, but time is money, it was quicker to do as @programming2C78B suggests and program a couple, putting them into a Linear or Duplication Pattern.
Seth Madore
johannesJGAKQ
johannesJGAKQ
I have thought about patterns, but how do I get rid of the retract moves between the pattern instances? Ideally I would end up with a continuous tool path, but my experience with patterns is that I get a full retract between each pattern instance?
If I select e.g. 10 holes and pattern them 30 times, I end up with 30 full retract and reposition moves that slows me down.?
DarthBane55
Put your clearance plane at a level acceptable for you, then manually edit the very 1st Z clearance height so you get your safe visual reference.  Not ideal to manually edit, but then you get the safe move and low retracts...
