How to allow axial cutting with round lathe insert?
smunzer8ZZFW
smunzer8ZZFW
Good Afternoon Everyone,
I am trying to turn a top as show below and I am running into and issue. I have this internal curve on the top of the top and I can not get the round cutter to push into. I have tried a few different tool definitions to no avail. Any guidance would be greatly appreciated.
akash.kamoolkar
@smunzer8ZZFW Looks like a bug. I will make a ticket for it.
Akash Kamoolkar
Software Development Manager
smunzer8ZZFW
Thank you.
smunzer8ZZFW
Do you know of any alternative toolpath I could use here?
akash.kamoolkar
A workaround would be to use a grooving insert with a face grooving holder to machine the same operation and set the grooving parameter to "allow radial and axial grooving". i am getting what looks like the desired toolpath.
Akash Kamoolkar
smunzer8ZZFW
When I try to recreate your tool paths so that I can do them on the opposite side, i seem to always get this message in the attached photo. It only happens when i select the facing version of the round tool.
smunzer8ZZFW
Update: after playing with the tool path, when I changed the clearance to the back of the holder, then the path was generated.
