How do I define such a lathe tool?
janus2
Message 1 of 10
janus2
Hello!
On the front side of a knob I need some fine engravings. For this I want to use this lathe boring bar tool. But I was not able to define it.
Thanks for any help
Jan
Replies (9)
Message 2 of 10
HughesTooling
If you want to use the engrave operation you have to use a chamfer tool, just set it up with the correct included angle.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
janus2
Hello and thanks for your answer.
But I don't quite understand.
I can only find/define a chamfer tool in the milling category.. When I choose such a milling tool for a front grooving on a lathe, I get a "tool not allowed" message.
Can you give me an example?
Jan
Message 4 of 10
HughesTooling
So you want to profile on a lathe not engrave?
Set up as a boring tool with hand set to neutral should work. If it doesn't like that you can try as a general tool and set the orientation to 90°. If these options don't work can you export your f3d and share here?
General tool rotated 90°
Mark
Mark Hughes
Message 5 of 10
janus2
Hello Mark!
I'm so sorry. English is not my mother tongue. That's why I called it engraving, because it's very fine.
But you're right: it's profiling. But the function that I have to use in Fusion is Turning Groove.
I defined a tool as you recommended (Hand neutral was the trick). But unfortunately I get the same error message again. The same error message for general tool rotated.
I have attached the file.
Jan
Message 6 of 10
HughesTooling
If you want to use grooving you have to use a grooving tool but no way to define the tool you have as a grooving tool. Only options might be profile and constrain the width of cut using the inner and outer radius so only a small area is machined.
Just noticed your file, I'll see what I can come up with.
Mark
Mark Hughes
Message 7 of 10
HughesTooling
The best I can come up with is a tool like below. Doesn't quite look right in the simulation but might be worth trying as the simulation is not 100%. File's attached. Take a look at tool #7
Mark
Mark Hughes
Message 8 of 10
janus2
Hello Mark!
Thank you for your efforts. That looks interesting. But there is no file. Just a picture.
Jan
Message 9 of 10
HughesTooling
Just edited my last post and added the file.
Mark
Mark Hughes
Message 10 of 10
janus2
Hello Mark!
A interesting tool!😁
But it seems to be working. I will test it.
It is astonishing that there is no normal solution for this, not so extraordinary, function.
Thank you very much
Jan
